Date/Time: Tue, 11 Feb 2025 14:00:17 +0000
Data export
View Count: 702
[2020-09-07 22:03:42] |
User336061 - Posts: 2 |
Hi I would like to export historical data of CFD contracts to a text file. How can I do it for 1minute bars? What are the avaiable time frames to download? For example JPN225 index, Brent Oil or Copper? |
[2020-09-08 14:05:08] |
John - SC Support - Posts: 37869 |
Historical (daily) data is already in a text format, so no export is needed. Just copy the file and use it as you want. Refer to the information here: Text/CSV Data Format If you are wanting to export Intraday data, then refer to the information here: Exporting and Importing Intraday Data Files For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-08 14:20:27] |
Thank you. Is there an information available about each symbol about historical data horizon? I noticed that historical data size is different for different instruments. |
[2020-09-08 14:52:37] |
In general, the amount of historical intraday data downloaded the first time is based on the following settings: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload Regarding the starting date for historical data for each of those symbols, that is variable. You just have to see what is available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-08 20:03:55
