Date/Time: Mon, 25 Nov 2024 11:41:40 +0000
CCI Average
View Count: 2456
[2014-02-05 11:51:40] |
narcese - Posts: 58 |
Can anyone share a step by step procedure to install the CCI average? Someone's help would be greatly appreciated. Any chance the aforementioned indicator can be used with S Charts? The CCI Average study plots an average of the Commodity Channel Index over a defined time period. thoughts? Date Time Of Last Edit: 2014-02-06 00:47:11
[2014-02-05 15:30:36] |
Sawtooth - Posts: 4120 |
Add the MA study, set the Based On to the CCI study, set the Chart Region to the same as the CCI study, set the Input Data to CCI. Go here and download the BasedOnExamples.StdyCollct for some examples: http://www.sierrachart.com/index.php?l=doc/AdditionalFiles.php |
[2014-02-06 02:50:29] |
We have created a Study Collection for you which contains a Commodity Channel Index and a 20 Length Moving Average of it. It is attached near the bottom of this posting. Here are the instructions to use the attached Study Collection: http://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html#SC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-06 07:35:06
CCI_with_Avg.StdyCollct - Attached On 2014-02-06 02:49:58 UTC - Size: 18.68 KB - 500 views |
