Date/Time: Thu, 17 Sep 2026 15:07:46 +0000
Account package set up
View Count: 818
[2020-09-07 16:44:53]
drraj - Posts: 1
Hi im interested in level 5 package and real time data feed for CME. however my trading account is with TD Ameritrade. I do understand that sierra doesnt provide services to TD.
i want to understand my alternative options for setting this up and the cost involved with them. i would prefer to keep using the TD account and use sierra live data feed but if its very costly to do that or not possible i am open to funding a new connected account for futures trading.
im new to this so need help in setting this up.
thank you
[2020-09-07 22:13:15]
It is not possible to trade directly from Sierra Chart to your TD Ameritrade account. If you just want to use Sierra Chart for charting and not trading, then we recommend using the following solution in order to be able to get the CME data at the Non-Professional rate:
Easy Solution to CME Funded Trading Account Requirement
Otherwise, if you want to trade from Sierra Chart, then you would need to find a broker that supports one of the Trading Services that we support. Our recommendation is to use the Sierra Chart Order Routing service. Refer to the information here:
Sierra Chart / Trading Technologies Futures Order Routing Service
You will find the full list of services that we support here:
Supported Data and Trading Services: Supported Services
