Date/Time: Tue, 11 Feb 2025 09:04:54 +0000
window -->Show compact tool values window - Tool values should always appear in horizontal
View Count: 986
[2020-09-07 05:40:08] |
SatG - Posts: 23 |
Hello, When I click window --> Show compact tool values window, resulting tool values appear as vertical for some charts and horizontal for some other charts. Please refer the attachment for more clarity. If it appears vertical, it occupies significant space in the chart. Is there any settings to do such that it always appear horizontal ? Regards, Sat |
[2020-09-07 07:47:06] |
User907968 - Posts: 826 |
Chart Drawing Tools: General Tool Settings 'Use Horizontal Compact Tool Values Window Layout' Chart Drawing Tools: Use Horizontal Compact Tool Values Window Layout (Global Settings >> Tool Settings >> General >> Chart Values) |
[2020-09-07 21:24:13] |
It can only be one way or the other. It makes no sense it would appear both ways within the same instance of Sierra Chart.
