Date/Time: Tue, 11 Feb 2025 08:48:19 +0000
New to SC questions.
View Count: 572
[2020-09-07 02:36:16] |
User264542 - Posts: 2 |
Hello there, Yes I used the search function before posting. 1. Is there any way to edit the columns in the trade activity log? I've tried to look for the settings but didn't find anything. For example getting rid of 'order action source', OR 'low during position'. 2. I know this isn't typically 'a thing' but sierra is so advanced I figured there's a shot. Is it at all possible to get RVOL for equities but for premarket? 3. While setting up for IBKR, I followed the guide to setup the API and such. #23 asks me to set currency code to SMART. I cannot find this option anywhere. 4. I need to keep IBKR's TWS or Gateway open at all times for SC to retain API connectivity correct? 5. I keep getting a msg that on startup that I still haven't bought any Denali services (which I haven't because I thought they're only for futures correct?). I did make payments of $36, and $20. |
[2020-09-07 19:22:28] |
John - SC Support - Posts: 37869 |
1. No, you cannot change the columns in the Trade Activity Log. 2. Yes, you can do this, but you would have to have a chart that has just the Premarket times that you are interested in and then use the Relative Volume study. Refer to the Session Times information here: Chart Session Times And refer to the Relative Volume study here: Relative Volume 3. There is no setting that needs to be set to SMART. That is an option when entering the symbol. It was just an informative statement in that step. 4. Yes, you would need to have TWS running whenever you are also running Sierra Chart. 5. You are correct, the Denali Exchange Data Feed is only the CME Group futures. The reason you are getting messages about that data feed is because you enabled the Data Feed itself, but you did not select any exchanges. You did not need to enable the data feed. We have disabled the data feed renewal, so you do not need to worry about that. Additionally, the data feed was free the first month, so you did not pay anything for it (the $20 is in your account). If you are interested in getting U.S. Equities data from us, then you would need to use the Sierra Chart Exchange Data Feed and enable the U.S. Equities exchange. Refer to the information here: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
