Date/Time: Tue, 11 Feb 2025 09:08:17 +0000
Data Feed with Sierra Trial
View Count: 512
[2020-09-06 19:47:48] |
adrianarcila - Posts: 1 |
I would like to know if i can use sierra Data feed service even tho i will be working with a trial of the platform for this month, i asked for it on Optimus Futures. After this 30 days i will probably pay for the Sierra Platform and Maintain my Data Feed monthly fee.
[2020-09-07 18:47:00] |
John - SC Support - Posts: 37869 |
Yes, you can enable the data feed while using a Sierra Chart trial. Just keep in mind that the data feed works on a calendar month, so depending on the exchange you select, you may have to pay for the data feed and the exchange fee for the full month of September. Refer to the following documentation to get started: Real-Time Exchange Data Feeds Available From Sierra Chart Let us know if you need more help. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-07 22:16:07
