Date/Time: Tue, 11 Feb 2025 09:02:19 +0000
bitmex order issue
View Count: 530
[2020-09-06 17:08:20] |
User223281 - Posts: 58 |
Hello, the connection to bitmex API somehow cancelled or changed my stop loss order... costing me a lot of money and im not sure why/what happened
[2020-09-07 22:01:20] |
This is not within the scope of our support and if you are having trouble with BitMex trading functionality then our recommendation is not to use it.
