Date/Time: Tue, 11 Feb 2025 09:10:51 +0000
Numbers Bars not displaying properly
View Count: 906
[2020-09-05 20:26:30] |
User443403 - Posts: 9 |
When I attempt to switch from a time based chart to a range based chart my cadlesticks get skewed into equal sized bars regardless of what the auction prints. http://www.sierrachart.com/image.php?Image=1599337365524.png Please advise how to rectify this. thanks! |
[2020-09-06 10:11:46] |
User907968 - Posts: 826 |
The candle bodies are not from the number bars study. Are you using the study/price overlay to create the candle bodies - Study/Price Overlay Study If so, you can use this option - Full Synchronization of Source Chart to Destination - to synchronize the charts Study/Price Overlay Study: Full Synchronization of Source Chart to Destination |
[2020-09-06 10:52:38] |
Yes those candlestick bars are not from the Numbers Bars study. Remove the study that is drawing them. Instead use this Input to draw the candlesticks: Numbers Bars: Open and Close Marker Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
