Date/Time: Tue, 11 Feb 2025 09:04:21 +0000
UK LSE Stocks
View Count: 699
[2020-09-04 22:42:10] |
jimskin - Posts: 127 |
Which datafeeds support UK LSE stocks?
[2020-09-06 11:00:08] |
The Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-06 11:00:24
[2020-09-06 12:26:51] |
Ok, I see. That exchange looks like a new addition. I'm assuming I won't need a real-time subscription for the LSE exchange as the feed is delayed. Is that correct? Also, how long is the delay, is it 20 minutes? Thanks
[2020-09-07 22:02:27] |
Yes the data is delayed. We are not really sure what the delay time is. You could also probably find out from the exchange. We would have to check on that. We can only tell when the market is open.
