Date/Time: Tue, 11 Feb 2025 08:44:46 +0000
Global profit and loss is not working?
View Count: 598
[2020-09-04 20:18:06] |
User968625 - Posts: 260 |
Hello, the global profit and loss is not working. I am attaching an image. is there a global setting that I am missing. I looked at the documentation See attached image thanks |
Attachment Deleted. ![]() |
[2020-09-06 11:01:37] |
You need to enter the Loss Trigger Value as a negative number. Refer to the information on this setting here: Global Profit/Loss Management: Daily Net Loss Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
