Date/Time: Fri, 25 Sep 2026 05:20:35 +0000
TD Ameritrade and Futures data service
View Count: 1621
| [2020-09-04 18:32:53] |
| Tov - Posts: 1 |
I've tried to make heads or tails from what I've read in the forum and what I see on the help page, but I'm still confused. You probably get this question a lot, so I'm sorry in advance. I'd like to use TD Ameritrade to trade my futures, but I'd like to use Sierra Charts for my charting and data feed(Denali?). I saw that you need to verify my TDA account, so I sent that account info with that electronic document I was required to submit. Is SC able to work with a TDA account? I need some assistance. Thank you! |
| [2020-09-04 19:14:03] |
We no longer are supporting TD Ameritrade as a means to verify you have a funded futures trading account. You can use the Denali data feed but use this method here to confirm you have an account: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
