Date/Time: Thu, 21 Nov 2024 12:37:36 +0000
Is there a way to select a chart QUICK?
View Count: 1202
[2020-09-04 17:41:40] |
User845052 - Posts: 75 |
In my workspace I have multiple charts open, but only trade 1. My trades require that I act within seconds sometimes. The problem is that I'm finding that I'm having an issue accidentally being on another chart and having the trade be missed. I try to click the trading chart before the trade but that proves to be a little inefficient to execute quickly and consistently. I know that you can "Goto chart." Is there a way that I can, instead of having to select the chart each time which takes too long, just assign a chart to automatically go to. Preferably with hotkeys? Can you make something like this? Would be much easier to just press a key before each trade and know that things will work. Thanks |
[2020-09-05 10:09:36] |
You could set up a control bar button for a Chartbook: Control Bar: Control Bar Chartbook Buttons And you can then also set up a keyboard shortcut as well for that Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-05 17:13:07] |
Hi SC, I actually meant a chart within a chartbook. I have a single chartbook across multiple screens. |
[2020-09-06 10:43:44] |
Yes we know. We are just giving you the closest available functionality.
[2020-11-06 21:49:53] |
Hello SC Since i'm still running into situations where the Chart Window shortcut would be useful, just following up. On the top menu there is a dropdown CB and CW. If you could set a keyboard shortcut for CW the same way as it exists for CB, i really think that could be helpful to many users since we often have many charts open. I wouldn't ask if i didn't think this was a simple feature to implement. I realize you have millions of hours of work to do on the platform; in any case I just want to keep this request relevant Thanks |
[2020-11-07 02:55:41] |
We will see about adding keyboard shortcuts for the chart windows where you can assign a keyboard shortcut to a particular chart number in the active Chartbook.
[2024-05-19 00:55:58] |
HumblyTrading - Posts: 179 |
Hello SC Team, Was this implemented, where a shortcut can be assigned to a specific window within the chartbook to make it active? Thanks |
[2024-05-19 15:10:01] |
John - SC Support - Posts: 36174 |
This has not been done.
[2024-05-20 18:49:32] |
ForgivingComputers.com - Posts: 959 |
Maybe not the perfect solution, but F4 and F9 move to the Previous and Next charts.
[2024-11-15 04:36:41] |
CoCoHimself - Posts: 9 |
Found myself in the same situation as OP. Multiple charts within the same chartbook, some have different plans and risk/reward setups. Being able to hotkey to a specific chart would be slick! I know its low priority but I hope you guys can get to it soon. <3
[2024-11-15 07:02:11] |
Sierra_Chart Engineering - Posts: 17133 |
You can quickly select a chart through the CW menu.
