Date/Time: Tue, 11 Feb 2025 08:27:23 +0000
onbly one day of data
View Count: 576
[2020-09-04 16:20:56] |
User630671 - Posts: 1 |
Hello, can you help me with my settings. I'm able just to scroll back the current day when I'm using numbers of trade per bar chart (tipically 10 o 20). Before I was able to scroll back more data and more days. Can you check if my service settings are well configured. I would like to trade futures (CL, gold, ES, Nasdaq) in us session and europe sessione and overnight. With the most deph available. Thank you inn advance Giacomo Siccardi |
[2020-09-05 10:18:20] |
Your service settings are all fine, so it is not an issue related to them. The first things to check are the simple things, like make sure that the Number of Days to load is set to something other than 1. Or if you are using a date range, that it is also set appropriately. Refer to the information starting here; https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad And refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
