Date/Time: Tue, 11 Feb 2025 08:10:35 +0000
Service Package Payment
View Count: 787
[2020-09-04 16:15:19]
User165132 - Posts: 1
Hey!
Just wanted to ask if I have made the right purchase:
- Im trading YM woth CQG data feed
- Im trading Intraday (mostly scalping)
- Im only using Volume Bars for my trading and Volume Profiles for analysis
Is Service Package 5 the right option in your opinion?
I dont need no more services such like data feed services am I right?
Best Regards and looking forward to working with your service!
[2020-09-04 18:04:41]
John - SC Support - Posts: 37869
It sounds like you could just use Package 3 rather than Package 5 from what you state. The one thing to look at is that package 5 allows for Drawn Volume Profiles, so that may be a reason to stay with Package 5. Refer to the information here for the differences:
Description of Service Packages and Pricing: Packages
Since you are getting your data through CQG, you do not need any other Sierra Chart Data Services.
Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu.
You can also go to this page in your browser:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
Login with your Sierra Chart Account Name and Password.
2. Choose the particular Service Package that you want to automatically renew and press the "Update" button.
3. Add sufficient credit to your Services Balance using any of the available payment options:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
For further information, refer to:
Sierra Chart Purchase and License Information: Renewing Access
Date Time Of Last Edit: 2020-09-06 11:09:07
