Date/Time: Tue, 11 Feb 2025 07:46:34 +0000
Futures symbols missing from SC feed
View Count: 500
[2020-09-04 13:38:59] |
TeeJay - Posts: 123 |
Hello, I am using the SC data feed but not the Denali feed. I do not need RT Futures. The thing is when I switch to SC-All Data in Trading Service for testing I have access in Find Symbol to the 10:10 delayed continuous Future symbols from the SC feed. But when using my live system which has SC data feed/IB trading service I only have access to the Future symbols from IB. Can this be managed somehow that I get access to the symbols from the delayed SC feed? Thanks |
[2020-09-04 19:27:08] |
No this is not going to work properly. Just use a separate installation of Sierra Chart for the delayed data feed: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
