Date/Time: Tue, 11 Feb 2025 07:53:49 +0000
[User Discussion] - Fill additional field in sc.GetUserDrawnChartDrawing()
View Count: 448
[2020-09-04 12:06:52]
TeeJay - Posts: 123
would it please be possible that you fill the field UseToolConfigNum in the s_UseTool structure that you return by sc.GetUserDrawnChartDrawing()?
It is always initialized with -1, so it does not return the configuration value that was used when added the drawing manually.
Why? Because that would make it a lot easier to identify certain drawings within ACSIL and work on with it.
I have certain studies that would refer on certain user added drawings which used a certain tool configuration.
At the moment I use different colors to identify, but this is a really bad workaround from a programming standpoint.
Thanks.
Date Time Of Last Edit: 2020-09-04 12:07:36
