Date/Time: Tue, 11 Feb 2025 08:19:10 +0000
No current 2020 data for $JCJ, according to CBOE the active symbol for 2020 is $KCJ
View Count: 758
[2020-09-04 02:44:52] |
User844388 - Posts: 9 |
Currently symbol $JCJ is available but no data for 2020, from cboe source below the 2020 data should be under $KCJ, but that symbol isn't available. from: http://www.cboe.com/index/dashboard/kcj#kcj-overview Ticker symbols KCJ, ICJ, and JCJ are "rotated" as time elapses. KCJ Jan 2021 maturity S&P 500 implied correlation Calculated using Jan 2021 equity options and Dec 2020 SPX options Quotation is suspended after the Nov 2020 SPX expiration ICJ Jan 2022 maturity S&P 500 implied correlation Calculated using Jan 2022 equity options and Dec 2021 SPX options Quotation is suspended after the Nov 2021 SPX expiration JCJ Not quoted until after the Nov 2020 SPX expiration Jan 2023 maturity S&P 500 implied correlation |
[2020-09-04 20:34:46] |
We will check into this.
[2020-09-05 09:40:22] |
Sierra_Chart Engineering - Posts: 18382 |
We need to contact our data provider about this.
[2020-09-05 14:47:10] |
Thank you very much, please update when you get more info.
