Date/Time: Mon, 25 Nov 2024 16:40:11 +0000
Cycle Tool Improvements
View Count: 1774
[2014-02-05 03:03:59] |
BruceWilson - Posts: 15 |
Thanks for improving the cycle tool recently. Is it possible to make some further improvements as follows please? 1. It would be good to have the option for cycles to move forward in time only rather than past and future as it does now. 2. It would also be good if there was a feature that allowed the user to enter the start date and time and an end date and time. Thanks again and best wishes B |
[2014-02-05 09:26:37] |
1. We will see about this. 2. We will see about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-08 23:45:09] |
Al SC Developer - Posts: 434 |
In ver 1091, there will be a new cycle tool option called "Draw Cycles Forward Only". This is off by default which is the tool current behavior. When turned on, the cycles will start with the first tool anchor and be drawn forward in time from that point. In terms of setting the start/end, the start is obviously set when the tool is first placed. To add or remove cycles, just change the number of cycles drawn using the "Cycle Number" property on the cycle properties dialog. As they are added/removed you can see the tool update on the chart to determine where to stop it. |
[2014-02-13 22:29:39] |
Thank you very much. Have just downloaded v.1091 and it is everything I had hoped for. Best wishes - Bruce
[2014-02-21 01:09:54] |
C. Notes - Posts: 129 |
Supercool...
