Date/Time: Tue, 11 Feb 2025 13:53:54 +0000
Volume at Price Threshold Alert V2 Help
View Count: 2221
[2020-09-04 01:55:17] |
User311677 - Posts: 16 |
I cant get Volume at Price Threshold Alert V2 to work. The Imbalance does not match with the Number Bar Imbalance. I followed your guide on Volume at Price Threshold Alert V2: Highlight Multiple Adjacent Bid or Ask Dominant Prices (Stacked Imbalance) but the imbalance shown does not match with Number Bar Imbalance in any way. |
[2020-09-04 05:11:09] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-09-04 16:52:55] |
User158665 - Posts: 44 |
This is my latest account.
[2020-09-04 18:14:11] |
John - SC Support - Posts: 37869 |
We really need to see a screenshot so we can understand what you are seeing. Please follow these instructions to get us a screenshot: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-08 16:25:19] |
I can't understand what the orange square is trying to show, I can't get it to highlight only the imbalances of 300% or more as we can do with the Numbers Bars. Or am I using it with the wrong purpose? |
[2020-09-08 17:28:13] |
The orange squares represent a price value that meets the criteria that you have setup in your Volume at Price Threshold Alert V2 inputs. In the case of the image you have supplied, it is displaying an orange square at each price level in which the Ask Volume minus the Bid Volume has a value of 1 or larger (Comparison Method = Ask Volume Bid Volume Difference, Volume Threshold = 1). If you only want to alert when the imbalance ratio is 300%, then you would set the Comparison Method to Ask Volume Bid Volume Ratio and set the Percentage Threshold to 300 (you use the Percentage Threshold here since it is a ratio). All of this is explained in the documentation for the study here: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
