Date/Time: Wed, 12 Feb 2025 04:13:02 +0000
Version 2146 - Line Extend to Edge showing dots
View Count: 663
[2020-09-03 23:34:19]
User104854 - Posts: 457
I use the line extend to edge for a particular study. In some cases I have the displacement at -3 so that the line extends into the chart. On this version the line only extends up to displacement 0 and then once I use a negative number it no longer shows up as a line but shows up as a dot instead at the displacement value. Can you check this out and fix it please?
[2020-09-05 19:55:59]
Ok. It's been a couple of months since I've posted any questions. You guys can get back to responding to me now. Is this something you can fix on this version?
[2020-10-02 16:59:42]
Can I get a response on this please? I've been waiting patiently for a month now and it seems like a simple solution. I'm still on version 2146 as I am waiting on some custom studies to get updated.
[2020-10-02 18:35:42]
We will try to get this in the next two weeks. It is going to take some time to figure out though because this is the result of solving another problem and may be just what you want to do could be considered unsupported now.
