Date/Time: Tue, 11 Feb 2025 08:19:10 +0000
Erroneous bar data returned from DTC server that does not show in chart
View Count: 622
[2020-09-03 20:41:23] |
CBR600RR - Posts: 37 |
I received the following 5 second bar data for BA on 9/1 at 11:59:05 from the DTC server: {"Type":803,"F":[1,1598975945,174.57009887695312,174.65370178222656,169.25999450683594,174.59999084472656,4370,42,4370,0,0]} However, this does not show up in the chart: http://www.sierrachart.com/image.php?Image=1599165395999.png Why does it not show up in the chart but is returned by the DTC server? You can see the low value of 169.26 is really out of wack and was actually the low of day value that occured at around 9:35 AM. Why is the DTC server sending bad data? |
[2020-09-04 05:04:50] |
This is not "bad" data. Use the Intraday Data editor to look at the values of the records which make up the 5 second records and locate this value and then provide us a screenshot. So we can understand this better. Instructions: Intraday Data Editor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-04 09:47:37] |
http://www.sierrachart.com/image.php?Image=159921284213.png
[2020-09-04 19:34:03] |
Ok we see what the problem is. We are putting out a new revision now to resolve this.
[2020-09-04 19:47:54] |
Update now to the latest prerelease.: Software Download: Fast Update This will resolve the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
