Date/Time: Tue, 11 Feb 2025 09:03:38 +0000
Sierra Chart Data Feed+Denali simultanously
View Count: 507
[2020-09-03 16:19:06] |
User212898 - Posts: 31 |
I already have Denali. Now, I would like to add CBOE Indices. Obviously, I need SC Data Feed for that. BUT: I want to have both Datafeeds within the same Instance because I will need to create studies between Charts of the same chartbook with CME Products and CBOE-Indices. Is this possible? IF I have to create an other account and have to run the CBOE Indices seperately (extra copy or instance), then I do not need it. Pleas give me advice! Thank you! |
[2020-09-03 19:53:42] |
You can have both the Denali Exchange Data Feed and the Sierra Chart Exchange Data Feed running at the same time to the same installation of Sierra Chart. There is no issue with this. You just need to setup the Sierra Chart Exchange Data Feed per the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Also refer to the information here on this topic in general: https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
