Date/Time: Tue, 11 Feb 2025 08:57:48 +0000
Rithmic Problem
View Count: 526
[2020-09-03 16:12:09] |
User854765 - Posts: 1 |
Hello, I cannot connect my data feed from Rithmic. A file is missing. I ask you to send them to me. Otherwise I cannot test your software. thank you
[2020-09-03 19:54:11] |
We really do not recommend using Rithmic with Sierra Chart and support for it will be coming to an end soon. Refer to our post here about this: Regarding Rithmic (Our Final Post on this Subject) But, here is where you will find the updates files you need: Rithmic Bridge Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
