Date/Time: Tue, 11 Feb 2025 09:04:09 +0000
CHART problem
View Count: 581
[2020-09-02 20:50:45] |
User695019 - Posts: 32 |
hello as you see in the picture there is 3 symbols linked but the third one which is ZB is not like others it has straigh moves can you tell me how to fix it. thank you |
[2020-09-03 00:25:06] |
What study are you using to create those lines in the chart?
[2020-09-03 12:39:19] |
OVELAY. look at is now it is all at the top. |
Private File |
[2020-09-03 19:50:32] |
We recommend using the Add Additional Symbol study. Refer to the information here: Add Additional Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
