Date/Time: Fri, 02 Oct 2026 13:21:17 +0000
Multiple key bindings for same tool?
View Count: 839
| [2020-09-02 18:26:45] |
| User266069 - Posts: 30 |
Hi, i draw a lot of horizontal lines with varying width i know there's config setting for shortcut my question is, is it possible to do it like below? E = horizontal line (width 2) R = horizontal line (width 3) T = horizontal line (width 5) etc the above skips a step Thank you Date Time Of Last Edit: 2020-09-02 18:27:20
| [2020-09-02 19:08:45] |
| John - SC Support - Posts: 48086 |
Yes, you can do this by first creating a Control Bar button and then creating the Keyboard Shortcut for it. Refer to the information here: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
