Date/Time: Tue, 11 Feb 2025 09:05:38 +0000
zig zag mode 1 percentage
View Count: 687
[2020-09-02 16:45:10] |
User873130 - Posts: 47 |
Hi Any chance to add into spreadsheet zig zag mode 1? When i send data to spreadsheet study, I see points and not percentage Thanks |
[2020-09-02 20:09:43] |
We are not understanding this.
[2020-09-02 20:34:40] |
if I set settings of zig zag indicator based on calculation mode 1 and Display length of zig zag line as Percentage, I would like to be able to see the value of the % in the spreadsheet. Currently, SG1 (zig zag value) and SG9 (zig zag oscillator) are based off points. Any chance to have option so that I will be able to see as percentage?
[2020-09-03 19:34:37] |
You will need to modify the study to meet your requirements: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
