Date/Time: Tue, 11 Feb 2025 08:43:07 +0000
How to get the chart to stop shifting vertically with new tick formation?
View Count: 555
[2020-09-02 15:36:00] |
User845052 - Posts: 75 |
It shifts slightly, annoying for managing stops in quick situations
[2020-09-02 16:02:40] |
John - SC Support - Posts: 37869 |
In order to set the chart so that it does not scroll up or down based on the bars, then refer to the information here: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-02 20:23:47] |
Also refer to this section to reset the scale and make sure it is properly set up: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-02 20:23:55
