Date/Time: Tue, 11 Feb 2025 08:33:00 +0000
Email Alerts
View Count: 1646
[2020-09-02 14:46:37] |
User680605 - Posts: 5 |
Can email or text alerts be setup when price reaches intended target?
[2020-09-02 15:26:42] |
John - SC Support - Posts: 37869 |
Yes, you just have to setup the Alert to either email or text. Refer to the information here and the section after it: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#EmailNotifications For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-02 20:21:52] |
Also refer to this page: Alerts Manager Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
