Date/Time: Thu, 19 Sep 2024 00:53:46 +0000
Why is Zenfire being referenced when Rithmic datafeed is being used?.
View Count: 1107
[2014-02-04 18:56:56] |
joeroma - Posts: 43 |
I have always used Rithmic for my datafeed. Never Zenfire. Why is Zenfire being referenced when I connected to Rithmic and an order showed Zenfire DTC rather than the usual Rithmic DTC. Why is Zenfire being referenced? This is the first time I have noticed this. Thanks. Software version: 1088 | 2014-02-04 06:02:53 Usage end date: 2015-02-02 | 2014-02-04 06:02:53 Enabled for: Sierra Chart Historical Data Service. | 2014-02-04 06:02:53 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-02-04 06:02:53 Active service: Rithmic Trading | 2014-02-04 06:02:53 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-02-04 06:02:53 2014-02-04 06:02:53 Local computer clock time | 2014-02-04 06:02:53 2014-02-04 14:02:53 GMT time | 2014-02-04 06:02:53 2014-02-04 06:02:53 Time zone adjusted time | 2014-02-04 06:02:53 Time difference to server time: 0 seconds. | 2014-02-04 06:02:53 Program path: C:\SierraChart\ | 2014-02-04 06:02:53 Data Files path: C:\SierraChart\data\ | 2014-02-04 06:02:53 OS Version Number: 5.1 | 2014-02-04 06:02:53 Checking for new symbol settings for rim | 2014-02-04 06:02:53 Rithmic Trading - Port for executable: 25348 | 2014-02-04 06:03:57 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-02-04 06:03:57 Rithmic Trading: Connecting to the server 127.0.0.1. Port 25348 | 2014-02-04 06:03:58 The network socket is connected. | 2014-02-04 06:03:58 Rithmic Trading: Connected to server. | 2014-02-04 06:03:58 Rithmic Trading: Sending logon request message. | 2014-02-04 06:03:58 Rithmic Trading - Starting the connection process to data and trading service. | 2014-02-04 06:03:58 Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-02-04 06:03:58 Rithmic Trading - Connecting to Rithmic 01 US server. | 2014-02-04 06:03:58 Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-02-04 06:04:00 Rithmic Trading - Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2014-02-04 06:04:00 Rithmic Trading - Server Alert: Trading System Connection Opened | 2014-02-04 06:04:00 Rithmic Trading - Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2014-02-04 06:04:00 Rithmic Trading - Server Alert: PnL Connection Opened | 2014-02-04 06:04:01 Rithmic Trading - Server Alert: PnL Connection Login Complete. Result text: "ok" | 2014-02-04 06:04:01 Rithmic Trading - Server Alert: Intraday History Connection Opened | 2014-02-04 06:04:01 Rithmic Trading - Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2014-02-04 06:04:01 Zen-Fire DTC Server Info - Server Name: Sierra Chart DTC Bridge. Server Version: 1.1. Provider Name: Zen-Fire DTC. | 2014-02-04 06:04:02 Zen-Fire DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-02-04 06:04:02 Zen-Fire DTC - Successfully connected. | 2014-02-04 06:04:02 Zen-Fire DTC: Requesting trade accounts from server. | 2014-02-04 06:04:02 Zen-Fire DTC: Requesting Trade Positions data. | 2014-02-04 06:04:07 Rithmic Trading - Starting real-time market data updates for: ESH4-CME | 2014-02-04 06:04:49 Chart #9 has tagged chart #10 for full recalculation. Chartbook: 2014MarContractDec1213.cht | 2014-02-04 06:05:12 . . . Zen-Fire DTC: Requesting Trade Positions data. | 2014-02-04 10:02:52 |
[2014-02-04 19:01:43] |
We will correct this. There were some changes that were done with the connect points in the bridge program that caused this. It is harmless, it is only a naming issue.
