Date/Time: Fri, 25 Sep 2026 16:47:46 +0000
sc.HeikinAshi code in SCStudyFunctions.cpp Seems Incomplete
View Count: 738
| [2020-09-02 04:50:37] |
| BlakJak - Posts: 108 |
I was looking at the sc.HeikinAshi intermediate function code in SCStudyFunctions.cpp and it appears not to set the "HighOut" and "LowOut" arrays. As per the "Studies.cpp" scsf_HeikinAshi(SCStudyInterfaceRef sc) study the logic should be: Heikin Ashi high: haHigh = the higher of High and today's haOpen Heikin Ashi low: haLow = the lower of Low and today's haOpen so it looks like the sc.HeikinAshi function is missing some code like: HighOut[Index] = max(HighVal, OpenOut[Index]); LowOut[Index] = min(LowVal, OpenOut[Index]); could you please fix that so I do not have to add the code manually myself to my strategy? |
| [2020-09-02 08:00:12] |
Yes we will update this in the next release.
