Date/Time: Tue, 22 Apr 2025 10:23:21 +0000
[User Discussion] - VPS / dedicated server in Chicago
View Count: 4885
[2020-09-01 21:50:52]
mazzy /| blast - Posts: 54
Searching for specs similar to this CX41 model
https://www.hetzner.com/cloud
VPS or dedicated
At the Chicago area... to achieve a ping sub 2ms to Aurora
Reasonable justified prices please, less than
http://www.theomne.net/virtual-private-servers
https://www.beeksfinancialcloud.com/
Date Time Of Last Edit: 2020-09-02 05:18:55
[2020-09-02 05:10:01]
HostVenom
https://hostvenom.com
PING ds1.sierracharts.com (8.18.161.135) 56(84) bytes of data.
64 bytes from 8.18.161.135: icmp_seq=1 ttl=123 time=1.19 ms
64 bytes from 8.18.161.135: icmp_seq=2 ttl=123 time=1.11 ms
64 bytes from 8.18.161.135: icmp_seq=3 ttl=123 time=1.17 ms
64 bytes from 8.18.161.135: icmp_seq=4 ttl=123 time=1.31 ms
--- ds1.sierracharts.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3006ms
rtt min/avg/max/mdev = 1.119/1.202/1.318/0.080 ms
Any other suggestions ?
Date Time Of Last Edit: 2020-09-02 08:23:35
[2020-09-02 07:43:54]
Beeks VPS in Chicago
Pinging ds1.sierracharts.com [8.18.161.135] with 32 bytes of data:
Reply from 8.18.161.135: bytes=32 time=3ms TTL=120
Ping statistics for 8.18.161.135:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 3ms, Average = 3ms
Date Time Of Last Edit: 2020-09-02 08:23:19
[2020-09-02 07:48:04]
http://www.theomne.net/virtual-private-servers/
Are the specifications of the Configuration 2 VPS solid enough to run smoothly in parallel several naked charts and DOMs of SC in fast market ? (manual trading)
Date Time Of Last Edit: 2020-09-02 07:48:37
[2020-09-02 08:24:16]
Speedy Trading Servers
https://www.speedytradingservers.com
image0EC3AEB8-4D10-4AAE-A80C-F0CE2CFD075A.png / V - Attached On 2020-09-02 08:23:55 UTC - Size: 13 KB - 564 views
[2020-09-02 11:18:05]
User75002 - Posts: 117
Thanks for the stats on these.
You can try Vultr VPS. Their Windows OS adds on to the price shown on this page.
https://www.vultr.com/products/cloud-compute/
[2020-09-02 11:48:41]
Thank you. Here is the ping for the Vultr VPS based in Chicago
# ping -c 5 ds1.sierracharts.com PING ds1.sierracharts.com (8.18.161.135) 56(84) bytes of data. 64 bytes from 8.18.161.135 (8.18.161.135): icmp_seq=1 ttl=122 time=1.13 ms 64 bytes from 8.18.161.135 (8.18.161.135): icmp_seq=2 ttl=122 time=1.02 ms 64 bytes from 8.18.161.135 (8.18.161.135): icmp_seq=3 ttl=122 time=1.01 ms 64 bytes from 8.18.161.135 (8.18.161.135): icmp_seq=4 ttl=122 time=1.08 ms 64 bytes from 8.18.161.135 (8.18.161.135): icmp_seq=5 ttl=122 time=1.08 ms
--- ds1.sierracharts.com ping statistics --- 5 packets transmitted, 5 received, 0% packet loss, time 4004ms rtt min/avg/max/mdev = 1.010/1.067/1.139/0.050 ms # mtr -rw ds1.sierracharts.com Start: 2020-09-02T11:42:47+0000 HOST: chi1458.vultr.com Loss% Snt Last Avg Best Wrst StDev 1.|-- gateway 0.0% 10 0.2 0.2 0.2 0.3 0.0 2.|-- 10.67.1.241 0.0% 10 0.9 2.6 0.7 12.6 3.8 3.|-- 10.67.5.6 0.0% 10 0.7 4.8 0.7 30.8 9.5 4.|-- 10.67.0.205 0.0% 10 14.3 6.8 0.9 15.7 6.1 5.|-- ae10-161.cr1-chi1.ip4.gtt.net 0.0% 10 0.8 6.0 0.8 36.7 11.6 6.|-- ae5.cr3-chi1.ip4.gtt.net 0.0% 10 3.6 1.8 0.9 7.2 2.1 7.|-- 78.152.59.10 0.0% 10 1.0 1.0 0.9 1.1 0.0 8.|-- 8.18.161.135 0.0% 10 1.1 1.1 1.0 1.1 0.0
[2021-03-26 07:11:02]
AndreyPoroshin - Posts: 105
Thanks for researching, so which of these options is the most optimal in terms of speed, usability, and cost?
[2021-04-16 16:32:28]
Richard58 - Posts: 4
For a Chicago VPS, I'd say www.ninjamobiletrader.com is most optimal in terms of speed, usability, and cost.
For speed, they use AMD Ryzen CPUs which blow away the typical Intel Xeons, single and multi thread.
https://www.cpubenchmark.net/cpu.php?cpu=AMD+Ryzen+9+3900X&id=3493
For usability, it's the first VPS I found where I can trade over remote desktop as the default. Unlike other VPS, this one does not have any chart lag.
For cost, it's basically half the cost of www.speedytradingservers.com
[2022-07-22 20:14:58]
User379468 - Posts: 508
What's the benefit to manual remote desktop trading to a VPS vs locally?
[2022-07-22 23:44:06]
There are different benefits based on your specific needs.
Some brokers do not hold server-side bracket orders, therefore if you had a pending limit order sitting above/below current price with a stop and target attached and lost connectivity and then the limit got executed, the stop and targets would not be sent to the exchange, leaving you unprotected.
Some people trade with market orders and find that the latency for execution is faster being closer to the exchange.
It comes down to personal preference based on your location, trading style and needs.
[2022-07-27 13:54:55]
I prefer to trade manually on my VPS vs locally because I use market if touch orders so that they're not sitting limit orders in the exchange books to prevent hunting out my stops. But simulated stop loss and market if touch orders are only local, and submit as market orders once the current price touches. The VPS has already paid for itself many times over just by not getting stopped out 1-2 ticks before reversing back into my profit direction. Likewise, going through the profit if touch orders, instead of never filling and reversing right at my profit target.
[2022-10-27 23:45:06]
User887126 - Posts: 85
i was researching MIT orders for sierra chart and came across this post. Are you specifically using MIT client orders? SC support informed that MIT orders are not supported. Also, i was wondering how VPS help manual trading. Other than using orders like MIT and trailing stop, i dont see any other significant benefits. i can do everything else on my local PC.
[2022-12-05 14:55:53]
Hello, for me I just like having my entire trading workspace in the cloud. Nice that it's backed up so can just switch between my home desktop and laptop and still use the same workspace.
[2023-10-28 00:13:16]
jeden8l - Posts: 48
Reactivating this thread a little bit as I'm now in the chase of a good VPS/dedicated server.
tradingfxvps.com- ping and chat attached.
Ninja Mobile Trader VPS- ping attached
I'm going to check a couple of more so will post here as well.
imagetradingfxvps ping.png / V - Attached On 2023-10-28 00:12:10 UTC - Size: 89.24 KB - 207 views
imagetradingfxvps chat.png / V - Attached On 2023-10-28 00:12:15 UTC - Size: 55.56 KB - 189 views
imageNinjamobiletraderVPS.png / V - Attached On 2023-10-28 00:12:22 UTC - Size: 91.28 KB - 213 views
[2023-10-28 12:50:37]
Careful with tradingfxvps, their Intel CPUs are actually quite laggy and I had frequent connection drops for my automated strategies, one of which cost me a couple grand loss and tradingfxvps support could care less. I actually ended up switching to Ninja Mobile Trader VPS about 2 years ago, and haven't had a single connection drop since.
[2023-10-28 13:04:40]
jeden8l - Posts: 48
Cheers Richard.
I also noticed their customer support is on the higher level.
Since the first inquiry I got assigned an account manager and been offered 1:1 screen session as an introduction.
