Date/Time: Thu, 01 Oct 2026 07:01:05 +0000
Switching to Sierra TT Routing
View Count: 769
| [2020-09-01 21:13:33] |
| User750920 - Posts: 297 |
I currently use GAIN and am looking to switch. Going to AMP and use TT routing. Will I have to change all the symbols in my charts and/or is there anything else I would need to do other than the Data/Trade Settings. Thanks |
| [2020-09-02 14:20:41] |
| John - SC Support - Posts: 48074 |
All of the information is in the Setup Instructions for the Sierra Chart Order Routing Service. You will find the information here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions You do not have to change the symbols. There is a command that automatically does that and the documentation linked above explains this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-03 06:03:52
