Date/Time: Fri, 07 Feb 2025 15:23:57 +0000
CandleStick Patterns Finder
View Count: 769
[2020-09-01 17:12:34]
Rino - Posts: 124
Please tell me how to color bar instead of
label.
image1mmmm.jpg / V - Attached On 2020-09-01 17:12:07 UTC - Size: 66.27 KB - 264 views
[2020-09-01 17:44:35]
John - SC Support - Posts: 37810
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-09-01 17:49:38]
User731023 - Posts: 139
Done
[2020-09-01 18:15:06]
If you want to change the color of the Pattern Finder text then you can do that from the Subgraph for that pattern. Refer to the information here:
Chart Studies: Subgraphs Tab >> Color
If you want to actually change the bar color at that same point, then you would use the Color Bar Based on Alert Condition. Refer to the following documentation for how to set an Alert for the CandleStick Patterns Finder:
CandleStick Patterns Finder: Accessing Pattern Results in Alerts, Spreadsheets and ACSIL
