Date/Time: Wed, 12 Feb 2025 11:40:42 +0000
TSLA strange bar values
View Count: 649
[2020-09-01 16:45:16]
CBR600RR - Posts: 37
I'm seeing some way out of wack prints today on TSLA. What are we supposed to do about these? Chart here: http://www.sierrachart.com/image.php?Image=1598978684799.png
[2020-09-01 18:15:16]
Sierra_Chart Engineering - Posts: 18393
Do you have Chart >> Chart Settings >> Advanced Settings 3 >> Include Odd Lot Equity Trades enabled for the chart? Disable that option.
We want you to re-download the data from before today following these instructions:
Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method)
That will remove these out of range values.
[2020-10-21 12:25:38]
UserAR - Posts: 64
I'm seeing these out of rang values for several different equity symbols especially in the pre-market. I have disabled odd lot equity trades. I've even tried filtering out trades below 100 lots and that does not help. It's so bad the chart is unusable.
imageout of range values.png / V - Attached On 2020-10-21 12:23:30 UTC - Size: 6.61 KB - 194 views
[2020-10-21 13:07:56]
This is a problem that happens a lot and is the reason I no longer use sierra chart. Still trying to get refunded for a basically unusable product. See here:
Erroneous bar data
