Date/Time: Thu, 19 Sep 2024 00:55:47 +0000
Data Feed
View Count: 1082
[2014-02-04 18:43:17] |
dimeetrees - Posts: 27 |
Hi just renewed my subscription to the data feed. Did you guys activate it on your end yet?
[2014-02-04 19:04:53] |
Yes. This is now done. It happens automatically. Restart Sierra Chart.
[2014-02-04 19:59:31] |
It doesn't seem to be working anymore. I had it set up and did not change anything. My subscription ran out and after I renewed it I couldnt get it to work.
[2014-02-04 20:36:18] |
We need to see the Message Log : https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-04 23:39:22] |
I finally got it, had to log into my live account. THanks for the support.
