Date/Time: Tue, 11 Feb 2025 01:31:45 +0000
Datafeed question
View Count: 535
[2020-09-01 15:29:33] |
User714262 - Posts: 8 |
Hello. I'm a bit confused right now.. I'm trying to get live data for CME and NYMEX (I want to trade GBP, S&P500 and oil futures), I'm going to use a retail broker platform to place my trades so I don't need a futures broker but then I found this link: Easy Solution to CME Funded Trading Account Requirement 1. So that means I NEED to open a AMP account to be able to get Live data? And I don't understand what the difference between "Denali Exchange Data Feed" & "Sierra Chart Exchange Data Feed" is. Yes I know Denali data feed is for CME, CBOT, NYMEX, and COMEX. 2. Does that mean I don't get those markets on Sierra Chart Exchange Data Feed? Is there any other differences? Between them? If I get CME, CBOT, NYMEX, and COMEX on Sierra Chart Exchange Data Feed, then why wouldn't I pick it? I get more data? Best regards Confused trader |
[2020-09-01 15:49:33] |
John - SC Support - Posts: 37869 |
1. It depends on who your broker is using for the trading service. If it is one of the services that we support, then you do not need a separate account. Refer to our list of supported services here: Supported Data and Trading Services: Supported Services But, if you do not have an account through one of our supported trading services and you do not want to be charged at the Professional rate, then the solution you reference is going to be the best solution. 2. The Denali Exchange Data Feed only has the CME Group of data. The Sierra Chart Exchange Data Feed has other exchanges, but does NOT have the CME Group. You also have to pay for each exchange that you want to have activated, so it is not a matter of more data. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-01 19:07:59
