Date/Time: Fri, 11 Sep 2026 12:26:16 +0000
TSLA Chart Not working
View Count: 819
| [2020-09-01 12:57:25] |
| Herrm24 - Posts: 2 |
Anyone having issues viewing TSLA chart on Sierra? Using TPO and it is not loading up
| [2020-09-01 14:13:17] |
| John - SC Support - Posts: 47841 |
We need more information to understand what is happening. When you say the TPO is not loading up, is it not displaying anything, is the information incorrect, or is it something else? Also, please attach a screenshot showing us what you are seeing.
| [2020-09-01 19:06:07] |
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
