Date/Time: Mon, 25 Nov 2024 11:20:27 +0000
DLP on the trading chart
View Count: 2180
[2014-02-04 16:03:24]
Ghtais - Posts: 11
My DLP value on my trading Dom doesn't want to show the daily LP in currency.
The realtime PL value is correct but the DLP value is in ticks instead of $.
I have set the Position Profit/Loss on currency and the currency value per tick at 12,5 witch works perfect for the P/L value but not for the Daily P/L.
Can you help me please.
I'am on simulation and my trading service is set to SC forex data (no broker)
[2014-02-04 18:38:25]
Please tell us the exact value you see for the Daily Profit/Loss and where are you looking at it. What we want to know is if you see a C after the value.
[2014-02-05 09:10:19]
Ghtais - Posts: 11
yes I see the "C" after this value
Please, look at the picture on this link
https://www.dropbox.com/s/h3lw26sr2qqvdsn/DOM.jpg
I would like to see my Daily profit loss in currency. 1 tick = 12,5$. In the picture you see -4 instead of -50,00$.
Is it possible ?
thank you
[2014-02-05 09:12:36]
Select Chart >> Chart Settings >> Advanced Settings 2. Set the Currency Value Per Tick to 12.5
[2014-02-05 13:02:37]
Ghtais - Posts: 11
I have already done this but it doesn't works It's why I don't understand.
It works with the P/L value but not with DPL
[2014-02-05 16:47:38]
This could be. This means the setting is also being picked up from Global Settings >> Symbol Settings. You need to change the Currency Value Per Tick value for the Symbol there as well.
Date Time Of Last Edit: 2014-02-05 16:47:59
[2014-02-05 17:01:18]
Ghtais - Posts: 11
Yes, already done too.
It changes nothing on the DPL. It works only on the PL
[2014-02-05 17:16:47]
Go to the chart and select Chart >> Reload and Recalculate. That should cause the trade list to be rebuilt and Daily Profit/loss calculations to use the new setting.
Date Time Of Last Edit: 2014-02-05 17:17:43
[2014-02-05 17:36:32]
Ghtais - Posts: 11
No I'am sorry but it doesn't work.
I took a few screen shoot to explain this issue.
During the trade everything is ok
https://www.dropbox.com/s/15a8qceeqxpklsc/duringtrade.jpg
I closed the trade at 9131 and DLP should now be +37,5 instead of +3.
https://www.dropbox.com/s/qykzw7n3rb1sxyd/aftertrade.jpg
[2014-02-05 23:04:30]
We are going to be testing this now.
[2014-02-05 23:37:39]
You need to reload your Trade DOM. The easiest thing to do is select Edit >> Reload All Charts.
[2014-02-06 09:28:17]
Ghtais - Posts: 11
Thank you for your help but It doesn't change anything. I reloaded, closed and open the trade windows with no success
I have the same issue on the trade activity log windows, the Cum P/L is in point even if I select Currency Value in the P/L format.
[2014-02-06 09:43:12]
We have verified again, that the calculations do work properly if you change the Currency Value per Tick to 12.5.
We suspect that the Currency Value per Tick in Global Settings >> Symbol Settings for GER30 is set to 1. Please check it. It can be reset when Sierra Chart is restarted.
You may want to uncheck Overwrite Existing Settings When Automatically Updating from the Server in Global Settings >> Symbol Settings.
[2014-02-06 09:44:07]
Here is the proof:
Symbol  Trade Type  Entry DateTime  Exit DateTime  Avg Entry Price  Avg Exit Price  Entry Quantity  Exit Quantity  Max Open Quantity  Profit/Loss  Cum P/L  Runup  Drawdown  Max Open Profit  Max Open Loss  Entry Efficiency  Exit Efficiency  Total Efficiency  Commission
[Sim]GER30  Long  2014-02-03 06:17:51  2014-02-03 06:22:12  9242.0  9235.0  10  10  10  -875.00  -875.00  0.00  -2250.00  0.00  -2250.00  0.00%  61.11%  -38.89%  0.00
At the top of the Trade Activity log we have selected Currency Value for the P/L format.
Date Time Of Last Edit: 2014-02-06 09:48:24
[2014-02-06 10:03:39]
Ghtais - Posts: 11
Ok, thanks you for your help :)
