Date/Time: Tue, 11 Feb 2025 01:34:20 +0000
Level 2 data stock
View Count: 1173
[2020-08-31 18:24:57] |
Torsten Grüß - Posts: 45 |
I wanted to ask if it is planned to offer Level 2 data for shares via SC
[2020-08-31 21:16:12] |
Right now the answer is no. It is not planned.
[2020-09-01 13:26:15] |
to the info my Brocker is IB is there any other way to get level 2 data in SC? Do you have a partner in the program ? |
[2020-09-01 16:20:25] |
John - SC Support - Posts: 37869 |
We work with the Interactive Brokers data. Therefore, you can get the data from them. Refer to the following Setup Instructions to connect to Interactive Brokers: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
