Date/Time: Thu, 19 Sep 2024 01:01:04 +0000
Cumulative Delta
View Count: 1426
[2014-02-04 15:19:46] |
gmorgan111 - Posts: 121 |
I have now switched over from IQ Feed to the Sierra Chart Data Feed and I must say it is everybit as good as the IQ Feed. Thanks! I have one problem though on the historical daily charts I can not run the cumulative delta volume. I added the study to my daily chart and there is no data on the chart. How can I run cumulative delta on the daily charts? Thanks |
[2014-02-04 17:25:57] |
To use the Cumulative Delta Bars studies on a Daily bar chart requires that you use an Intraday chart with the bars set to 1 day. The general instructions to do this are documented in this section here: http://www.sierrachart.com/index.php?l=doc/helpdetails13.html#DaySessionOnlyDaily The only difference is that you will want to set the Start Time and End Time to cover the full 24 hour session, assuming that is what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-04 17:27:23
