Date/Time: Tue, 11 Feb 2025 01:25:49 +0000
connexion rithmique
View Count: 575
[2020-08-31 16:01:54] |
User740715 - Posts: 26 |
Rithmic Trading | Message from server: Error creating the main object. Error message: os error | 2020-08-31 17:59:04.153 Rithmic Trading | Received logon response. | 2020-08-31 17:59:04.154 Rithmic Trading | Server Name: DTC Bridge. | 2020-08-31 17:59:04.154 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-08-31 17:59:04.154 Rithmic Trading | Logon error received from server | 2020-08-31 17:59:04.154 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-31 17:59:04.154 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-31 17:59:04.154 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-08-31 17:59:04.154 DTC Client socket (1) | CloseSocket call. | 2020-08-31 17:59:04.155 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-08-31 17:59:04.155 DTC Client socket (1) | Closed. | 2020-08-31 17:59:04.155 Rithmic Trading | Waiting for socket receive thread to end | 2020-08-31 17:59:04.167 DTC Client socket (0) | CloseSocket call. | 2020-08-31 17:59:04.167 Rithmic Trading | Disconnected. | 2020-08-31 17:59:04.167 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-31 17:59:04.167 Rithmic Trading | Port for executable: 55507 | 2020-08-31 17:59:06.172 Listening socket (1736). Port 55507 | Closed. | 2020-08-31 17:59:06.172 Rithmic Trading | Starting server: F:\SierraChartDamien\Rim\DTCBridge.exe | 2020-08-31 17:59:06.177 Created process F:\SierraChartDamien\Rim\DTCBridge.exe. Current folder: F:\SierraChartDamien\Rim | 2020-08-31 17:59:06.971 |
[2020-08-31 16:08:56] |
Sierra Chart has terminated support for Rithmic: Regarding Rithmic (Our Final Post on this Subject) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
