Date/Time: Tue, 11 Feb 2025 01:52:56 +0000
Study summary vs Text display study
View Count: 624
[2020-08-31 15:22:09] |
User977098 - Posts: 28 |
Hello, I have a chart with a spreadsheet study on it. The spreadsheet has 20 columns of calculations that I am wanting visualise quickly. My question is, is it better to show the results via the study summary window (which is what I am guessing) or to include a text display study for each calculation that I can put on the chart screen. (When I say better, I am only talking about what would put less demand on my computer.) Thanks |
[2020-08-31 16:12:05] |
You really should do your own testing to properly evaluate what is best for you. And there really is not going to be any difference.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-31 16:20:31
[2020-08-31 19:38:57] |
Ackin - Posts: 1865 |
to User977098)For xx values you will have more loading arrays. If you have a choice I would definitely choose the Summary window (it is very well optimized to display multiple values at once). btw. I solved this at the output from automatic systems and at a lot of text values it slows down the graph (experience from v2092). At 20 values, the difference will be negligible. Date Time Of Last Edit: 2020-08-31 19:39:14
