Date/Time: Mon, 25 Nov 2024 10:39:05 +0000
Lock volume profile
View Count: 1249
[2014-02-04 11:32:48] |
AKR - Posts: 523 |
Seems it is possible to look drawings, but not volume profiles? Would be a nice feature for VPs as well. cheers |
[2014-02-04 14:18:55] |
AKR - Posts: 523 |
I meant only VPs that are drawn by the VP drawing tool ..
[2014-02-05 00:51:46] |
We will check on this.
[2014-02-05 19:59:01] |
Al SC Developer - Posts: 434 |
In ver 1090, you will be allowed to lock/unlock drawn volume profiles from the context menu like other chart drawings.
