Date/Time: Tue, 06 Oct 2026 08:25:49 +0000
Error message on study recompile I don't even have
View Count: 866
[2020-08-31 12:09:10]
TeeJay - Posts: 123
Please see line before last line
This file is not even there
Please advise
image2020-08-31_SierraChart_64-083.jpg / V - Attached On 2020-08-31 12:09:03 UTC - Size: 96.88 KB - 305 views
[2020-09-01 16:23:26]
John - SC Support - Posts: 48114
You can ignore the message, as it is not causing any issues, but if you want to get rid of the file and the error, then go to the directory on your system - D:\Trading\SierraChart\Data and remove the file named Studies.dll.
[2020-09-01 16:42:18]
TeeJay - Posts: 123
John,
this is the thing, I don't even have a studies.dll in my Data folder, there is only studies_64.dll. So this error message is based on an error if you liketo say it like that. The file does simply not exist at all.
[2020-09-01 17:26:31]
Delete the file named Studies_64.dll. The _64 is just indicating that it is for 64 bit computers. That is ignored in the Message Log, so that is the file that is being referenced.
