Date/Time: Tue, 11 Feb 2025 01:54:56 +0000
Problems with installing Sierra Chart
View Count: 745
[2020-08-31 11:25:02]
Vanigan - Posts: 2
I tried to install Sierra chart in my laptop, however, when I try to install it I get the following message.
Windows protected your PC
Microsoft Defender SmartScreen prevented an unrecognized app from starting. Running this app might put your PC at risk.
Application: SierraChartFileDownloader.exe
Publisher: Unknown publisher
There's no way I could skip this message and go forward. The only option available to choose is Don't run.
All help is appreciated, thanks.
Regards,
Nivan-Moori Tamilar
imageSierra chart installation problem.jpg / V - Attached On 2020-08-31 11:24:25 UTC - Size: 1.48 MB - 224 views
[2020-08-31 14:07:34]
You need to find out how to disable Microsoft Defender SmartScreen.
Date Time Of Last Edit: 2020-08-31 14:09:14
[2020-08-31 15:12:42]
John - SC Support - Posts: 37869
Usually if you select the option for "More Info" it will give you an option at the bottom that states "Run Anyway". Select that button to allow the installer to run.
