Date/Time: Tue, 11 Feb 2025 02:02:29 +0000
DOM Problem
View Count: 539
[2020-08-31 05:37:50]
User538205 - Posts: 1
Hello I have problem with DOM .. When I open Forex DOM chart and the numbers are wrong and it is not showing volume but I activated it generally it is not in order .. I upload picture of GBPCAD DOM chart for you to see it ..
imageAnnotation 2020-08-31 100404.png / V - Attached On 2020-08-31 05:36:21 UTC - Size: 33.4 KB - 203 views
[2020-08-31 17:01:14]
The problem is you have changed the Price Display Format. Follow the instructions here:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
