Date/Time: Tue, 11 Feb 2025 09:05:23 +0000
SWBI Massive chart error
View Count: 586
[2020-08-30 18:51:39] |
TeeJay - Posts: 123 |
Hello, what happened to this chart? I already deleted and redownloaded, this made it look different but even worse This is not what SWBI looks like in real Can you please investigate? http://www.sierrachart.com/image.php?Image=1598813366874.png Thanks Date Time Of Last Edit: 2020-08-30 18:52:41
[2020-09-02 19:39:34] |
The data looks fine now: http://www.sierrachart.com/image.php?Image=1599075554266.png Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-03 13:07:37] |
Apparently this looks way better now, thanks
