Date/Time: Tue, 11 Feb 2025 01:43:55 +0000
View ALL Chartbooks on my other computer
View Count: 546
[2020-08-29 16:06:59]
User681150 - Posts: 62
i auto sync to a cloud service my Chartsbooks and collections, then sync cloud back to local drive. On the other computer I am not able to view the chartbooks. i see i can manually select files/folders send to user but want to remove the manually process every time i use one of my computers.
whats the best way to sync /cht files with cloud service. is there another file that must be shared between both computers in order for the .cht file to be viewable (some config file or something)?
thanks
[2020-08-31 16:04:07]
Why is this the case?.
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
Date Time Of Last Edit: 2020-08-31 16:04:27
