Date/Time: Mon, 21 Sep 2026 09:02:13 +0000
best way to convert SCDateTime to db and back
View Count: 3916
| [2020-08-29 08:21:58] |
| User658985 - Posts: 30 |
I'm reworking all my studies to support the new SCDateTime format. I tried a couple of things and it didn't quite work, thought i'd just ask you guys. So whats the best way to save this as a string to a db, then convert it back to SCDateTime? From what i understand, its an int now, so i tried something like this but didnt work: int dateInt = sc.CurrentSystemDateTime.GetDate(); SCString dateStr = SCString().Format("%d", dateInt); SCDateTime dt; dt.SetDate(dateInt); I could simply just continue to save it as a double. Is there a preferred way that allows for better future compatibility? |
| [2020-08-31 16:46:13] |
Refer to this function: Working with the SCDateTime Variables and Values: GetAsDouble() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-10-11 17:03:01] |
| User99735 - Posts: 234 |
Hi, Roundtripping of SCDateTimeMS to double and back is not working. SCDateTimeMS startDateTime = SCDateTimeMS(2021, 10, 7, 1, 1, 1); double datetime = startDateTime.GetAsDouble(); SCDateTimeMS endDateTime = SCDateTimeMS(datetime); sc.AddMessageToLog(SCString().Format("datetime %s", sc.DateTimeToString(endDateTime, FLAG_DT_COMPLETE_DATETIME_MS)), false); is printing gibberish. Vivek |
| [2021-10-12 03:29:03] |
| Sierra_Chart Engineering - Posts: 24913 |
There is a mistake in your code. This does not return a string pointer: sc.DateTimeToString(endDateTime, FLAG_DT_COMPLETE_DATETIME_MS) Refer to: ACSIL Programming Concepts: Working with SCString, Text Strings and Setting ACSIL Structure Member Name Strings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
