Date/Time: Tue, 11 Feb 2025 08:57:48 +0000
volume study
View Count: 675
[2020-08-28 16:48:08] |
User425645 - Posts: 113 |
Is there a way to set the volume study to only total size above said volume size? so basically an accumulation of tape blocks but as the volume study? sorry its kind of hard to explain. Thanks |
[2020-08-28 17:26:48] |
Ackin - Posts: 1865 |
your question can be interpreted differently...maybe attach a picture of what you think
[2020-08-28 21:37:46] |
We are not sure exactly what you are looking for, but our best guess is that you are looking for Volume Filtering. Refer to the information here: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-02 01:07:21] |
will this tell me when tape volume is higher then other periods?
[2020-09-03 18:50:16] |
For that use the Relative Volume study: Relative Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
